Invader Mk3 - Ballast Resistor & Handbrake Cable
MrRoJangles
Mem No.: 2671
Postby MrRoJangles » Tue Aug 23, 2016 12:13 pm
Hello All,
Sorry if these questions were asked before. I got a new ballast resistor from Brian, but cannot see where in the car this is? can anyone help?
Also, I need a new handbrake cable does anyone know if this is specially made for the MK3 or can I buy one from a auto spare shop? If so what was the donor car?
Thank you in advance
Re: Invader Mk3 - Ballast Resistor & Handbrake Cable
Postby Gavin McArdle » Wed Aug 24, 2016 2:59 pm
Hi Mr RJ, the ballast resistor may have been moved or removed by a previous owner. There should be 2 wires attached to the + side of the coil one of these ( white?) should lead to the ballast resistor.
If it has been removed completely then I would think the coil has also been replaced, a ballast resistor needs to run with a 9v coil.
The car would also originally have been fitted with a 4 terminal starter solenoid the threaded terminal also leads to the ballast resistor.
If you need a wiring sketch let me know (address in front of Rarebit) and I'll draw you one.
The handbrake cable is a specific length for a Gilbern, all model h/brake cables are available from BG
MrRoJangles
Mem No.: 2671
Postby MrRoJangles » Thu Aug 25, 2016 3:07 pm
Thank you Gavin for your response. I will look again for the resistor and wait BG to return to get my hands on the cable.
Postby Admin » Sat Aug 27, 2016 9:45 am
On the Mk3, the ballast resistor should be on top of the chassis rail, nearside in front of the brake servo.
I replaced my my handbrake cable with a Contina Mk3 (the donor of the axle) - looked identical to me.
Mem No.: 2297
Postby Fareham GT » Mon Aug 29, 2016 8:34 pm
Hi,
BG is back, so handbrake cables are back on the market! Buy now while stocks last.
Brian - Spares
MrRoJangles
Mem No.: 2671
Postby MrRoJangles » Wed Aug 31, 2016 5:06 pm
Thank you Admin and Fareham GT, BG shipped the cable yesterday, still no joy with locating resistor.
GGenie69
Mem No.: 915
Postby GGenie69 » Thu Sep 08, 2016 9:43 am
A previous owner may have replaced the coil with a 12v unit. No ballast resistor needed.
Richard
