Smell of petrol
blue1
- Mem No.: 2421
Smell of petrol
Does anyone else has the same experience of a strong smell of petrol coming from the boot. Also some people have commented that they can smell petrol around the car.
- craig 12
- Mem No.: 2394
Re: Smell of petrol
ive had that , yes its been ticking over admitidly, but sometimes before and after.
as my uncle frank always said" it never rains in the tap room"
Richard Adams
- Mem No.: 2144
Re: Smell of petrol
Hi if you can smell petrol that strong you have a problem which needs sorting. The tanks are made of mild steel and the bottoms often sit in a puddle of water in the boot and eventully they get porous. Other possibilties, one of the tank outlet or inlets have split away from the tank, the hose connecting the two tanks is leaking or the inlet pipe conection to the fuel filler is leaking. I spent ages trying to find out where my leak was coming from and traced it to one of the bottom outlet pipes which is brased to the tank and the brase had split. Roger Spares supplied a second hand tank that cured it instantly. Good luck
