Accelerator foot pedal
welshrat
Mem No.: 2448
Postby welshrat » Sat Feb 27, 2010 8:48 pm
Hi all,
Does anyone know where I can source an accelerator foot pedal for a MK1 Invader, looking for the under foot part with hinge that bolts to the floor. Existing acc. lever has a rubber/nylon roller on the bottom end, guessing this runs in groove on the underside of foot part. Looking to purchase new or used, difficulty I have at the moment is not sure what car they came from or even what they look like.
Thanx,
meier851
Mem No.: 430
Re: Accelerator foot pedal
Postby meier851 » Mon Mar 01, 2010 1:37 pm
John,
try Melvyn Rutter Ltd., the Morgan parts dealer. In their catalogue (not online) you find an arrangement as used by Gilbern, though, marked "Cosmic", possibly the original manufacturer. On my Mk. III there is no grove on the pedal (making the arrangement a bit wobbly) and not even a roller on the linking lever. I wanted to improve on this, way I looked around for parts sources.
Bruno Meier
Postby Greybags » Mon Mar 01, 2010 3:21 pm
Bruno..
Do you think you could scan it and post a picture of it on here please because as you say the catalogue in not online, and I think there may a few who would like to see a possible improvement to the pedal.
Many thanks
welshrat
Mem No.: 2448
Postby welshrat » Mon Mar 01, 2010 7:38 pm
Thanx Bruno,
Sc parts have an on-line dogalog for Austin Healeys (plus lots more), I wondered if this might be the original pedal, although the hinge appears to fix to the floor on the side, I assumed it would fix under the pedal. The following link takes you to the parts page http://www.scparts.co.uk/index/lang-2/l ... gtop=-2000
Sc parts is http://www.scparts.co.uk
welshrat
Mem No.: 2448
Postby welshrat » Mon Mar 01, 2010 7:48 pm
Forgot to wish everyone a happy St Davids Day, Patron Saint of Gilberns!
regards,
Mem No.: 612
Postby rocketman » Mon Mar 01, 2010 9:33 pm
The original pedal does bolt to the floor, it has a smooth surface on the back and the rubber wheel runs up and down just fine.
The pedal also has a grease nipple protruding out of the left-hand end of the spindle. Over the decades my original pedal seized and 'disappeared'. during rebuild I machined up a new pedal to original pattern. If required I can provide a photo.
Stu.
welshrat
Mem No.: 2448
Postby welshrat » Mon Mar 01, 2010 9:42 pm
Hi Stu,
A photo would be great, thank you very much.
Mem No.: 612
Postby rocketman » Wed Mar 03, 2010 1:37 pm
Hi Guys, I have tried to put some photo's on here but apparently need to reduce the resolution? I have the photo's in Picasa but cannot see where i can change the resolution. Any suggestions on this would be of help.
Stu.
Postby Greybags » Wed Mar 03, 2010 1:41 pm
You should be able to link to the pictures in Picasa by using it's URL between the "Img" links at the top of the page.
That way you dont have to reduce the resolution and we can see nice big pictures ..
Hope this helps...
Mem No.: 612
Postby rocketman » Wed Mar 03, 2010 2:10 pm
Sorry Graham, tried exporting file to the web in Picasa but do not understand what is required for URL and linking to IMG?
Postby Greybags » Wed Mar 03, 2010 4:12 pm
I didn't know that much about Picasa but have just created an account..
So .. load your picture up to Picasa, then go to your "my Photos" in Picasa, Click on the picture you want to load on here, and on the right hand side bar a "link to this photo" appears.
Click on this and 2 more boxes appear... Link and Embed object
Put a tick in the box that says "Image only (no link)" and select size large or medium
and then copy the URL in the embed obect box.
On you Gilblog message page click on the IMG box above your message box, and this will put (IMG) (/IMG) on you message.
Paste the URL you copied from Picasa between these 2 IMG boxes, and your picture will be displayed on the screen
Like this (img]http://lh6.ggpht.com/_Bu-lE0sEvkQ/S46QZSCa8FI/AAAAAAAAADA/_WtQlW_W3Us/s800/IMG_0196.JPG[/img)
This wont be seen when the message is displayed
Hopefully this will then display a photo something like this ..
Hope this helps
P.S. Flikr is easier
Mem No.: 612
Postby rocketman » Wed Mar 03, 2010 5:16 pm
deleted
Mem No.: 612
Postby rocketman » Wed Mar 03, 2010 5:18 pm
deleted
Postby Greybags » Wed Mar 03, 2010 5:31 pm
Rocketman ..
You are using the "Link to this album" when you have more than one picture on the screen..
Click on just one of the pictures so that it is large and in the centre of the screen, then you will get the "Link to this photo" line ..
You are also not pasting the link between the 2 (IMG) (IMG) boxes, but after them
Can you delete the post with the errors please..
If you want any more help, please give me a ring and I will happily talk you through it.. My number is in the back of Rarebit ..
Mem No.: 612
Postby rocketman » Wed Mar 03, 2010 5:40 pm
deleted
