mk 1 Invader sun visors
johnmcg
Mem No.: 2542
Postby johnmcg » Tue Jan 07, 2014 7:44 pm
Anybody got a fix for saggy sun visors ? The bolts are tight but the blocks on the roof to which they are attached are loose.
John
3cpb
Mem No.: 2362
Re: mk 1 Invader sun visors
Postby 3cpb » Mon Jan 13, 2014 7:51 pm
Hi john,
I have a mark 2 and would presume the mk1 is similar, the sunvisor is connected to a mild steel bar drilled and threaded to hold the visor one end and bonded to the fiberglass above the door the other. First remove visor from the bracket (2 screws) then pull down rubber draft extruder at the top of the door and (a ) post , very carefully turn down head lining which is glued and held under this rubber, be careful its easy to rip. This should now give you enough room to re bond the bar back in place.
let me know how you get on,
Colin.
johnmcg
Mem No.: 2542
Postby johnmcg » Tue Jan 14, 2014 3:35 pm
Colin
many thanks for the advise. I'll progress carefully!
John
Users browsing this forum: No registered users and 6 guests
