Having sorted out the backs of the seats...........
One of the many points my tester raised was that the off-side rear suspension required considerable more force to compress than the near-side. Not a MOT fail but detrimental to handlng.
He said the shock absorbers must be miss-adjusted but my thoughts were that the springs themselves may be different rates. Am I off track?
Next question then....springs or shocks?
Re: Next question then....springs or shocks?
Reddi-Eng wrote:He said the shock absorbers must be miss-adjusted but my thoughts were that the springs themselves may be different rates. Am I off track?
Not necessarily. The difference being that shocks will not support a load, only resist position change (unless they're or something else is seized).
Without resorting to spanners a simple test is apply the same load, slowly two both sides (one at a time) and measure the wheel deflection. In practical terms, on level ground, jack each wheel up by a set amount. If the deflection is wildly different from side to the other, the springs don't match.
alastair_james_cox
- Mem No.: 2376
