Next question then....springs or shocks?
Reddi-Eng
Mem No.: 2089
Postby Reddi-Eng » Mon Feb 25, 2008 7:28 pm
Having sorted out the backs of the seats...........
One of the many points my tester raised was that the off-side rear suspension required considerable more force to compress than the near-side. Not a MOT fail but detrimental to handlng.
He said the shock absorbers must be miss-adjusted but my thoughts were that the springs themselves may be different rates. Am I off track?
Derek
_______________________________
Ex owner of 1973 Mk.III Invader PGY 161L
1988 GTM Rossa Mk.I
2010 Ford Fiesta Everyday Drive
Re: Next question then....springs or shocks?
Postby Admin » Tue Feb 26, 2008 9:10 am
Reddi-Eng wrote:He said the shock absorbers must be miss-adjusted but my thoughts were that the springs themselves may be different rates. Am I off track?
Not necessarily. The difference being that shocks will not support a load, only resist position change (unless they're or something else is seized).
Without resorting to spanners a simple test is apply the same load, slowly two both sides (one at a time) and measure the wheel deflection. In practical terms, on level ground, jack each wheel up by a set amount. If the deflection is wildly different from side to the other, the springs don't match.
alastair_james_cox
Mem No.: 2376
Postby alastair_james_cox » Tue Feb 26, 2008 11:41 am
Hi there,
Just had this problem with my GT - I think.
Passed the MOT but one side of the rear end is softer and sits lower over the wheel.
The car has new shocks form the club so I guess it must be the springs(?).
Is there any way of confirming this / are the springs marked in any way ..
Al.
Users browsing this forum: No registered users and 22 guests
